joepops
- Feb 8, 2005
- 3
I have an assyA consisting of other assys(B,C,...). In assyB, I included a part that consists of only points and lines which I wish to use for constraining in assyA. I also have a part in assyA with points and lines for constraining. When I attempt to use a line from the subpart in assyB in a constraint at the assyA level, I get the message "This geometry can not be selected because its exposition in PLM is not sufficient. Select another geometry or publish it before use it."
So I publish the items within the subpart of assyB, but that didn't help. It appears that I cannot use items from two levels down in assyA constraints. Is this the case and how should I correct it?
The parts have no planar surfaces, which is why I want to use the subpart with lines and points and I need to use multiple assyB parts.
Any help appreciated.
