assy-sketch-Can I break associativity of offset-sketch, from it's part 1
borsht
268
I have a sketch on an assembly, that is an offset of a surface of a part in the assembly. I want to fix the sketch, where it is and not have it be able to change as the associated part changes. There's a lot of entities to it. Is there a way to break this associativity rather than pick each entitiy, and delete the offset entity relation? I'm using 2003.
In your sketch tools toolbar, click the "Display/Delete Re;ations" button (or menu picks "Tools --> Relations --> Display/Delete...") to see your constraints. In the drop-down list at the top, select "External".
From this menu, you can view and delete all of the offset constraints.
[bat]Due to illness, the part of The Tick will be played by... The Tick.[bat]
