ASTM A36 vrs ASTM A615
boz9999
8
I am on a project which specifies the following for load transfer dowels in a junction slab (Basically the slab that prevents overturning when a vehicle hits a traffic railing mounted on a MSE Wall, the dowels transfer the load at expansion joints):
Dowel Load transfer devices will be ASTM A 36 smooth round bar and hot dipped galvanized.
And the certification for that bar submitted states the following:
1" Round Grade 60/A706
ASTM A615M-12 GR 60/A706 CE.50 Max / AASHTO M31-07
Can this be substituted for A 36?
During my investigation it appears the only different is that A615 Grade 60 has a higher yield strength but less ductile.
Thoughts?
What is the expected (credible minimum probable) temperature at the installation site?
A36 is a fairly weak steel. Is that an older spec?
North East Florida so occasionally in the 20's.
It is from the FDOT design standards for 2015.
So essentially the A615 is a better product? Can you comment on the differences?
A36 addresses steel yield strength of 36 ksi minimum. A615 is the Standard Specification for Deformed and Plain Carbon-Steel Bars for Concrete Reinforcement. A615 can have more than one specified yield stress, greater than 36 ksi.
ASTM A615 / A615M - 09b Standard Specificationfor Deformed and Plain Carbon-Steel Bars forConcrete Reinforcement
Abstract
This specification covers deformed and plain carbon-steel bars for concretereinforcements in cut lengths and coils. Materials considered under this specificationare available in Grades 40 [280], 60 [420], and 75 [520]. Steel samples shall be rolledfrom properly identified heats of mold cast or strand cast steel using electric-furnace, basic-oxygen, or open-hearth. Heat analysis shall be performed wherein steelmaterials shall conform to required compositions of carbon, manganese, phosphorus,and sulfur. Steel specimens shall also undergo tensile tests and shall conform torequired values of tensile strength, yield strength, and elongation. Steel samples shallalso undergo deformation test, tension test and bend tests. Final products shall bemarked by a tag.
ASTM A36
1. Scope*
1.1 This specification covers carbon steel shapes, plates, and bars of structural quality for use in riveted, bolted, or welded construction of bridges and buildings, and for general structural purposes.1.2 Supplementary requirements are provided for use where additional testing or additional restrictions are required by the purchaser. Such requirements apply only when specified in the purchase order.
Okay, does anyone see a problem substituting A615 Grade 60 steel dowel for a A36 steel dowel?
It appears the A615 is a better product.
You actually show 3 different specification...A36;A615;A706
For doweling purposes, either A615 or A706 is superior to A36
If you use A615 (a piece of rebar) at the expansion joint, you cannot cast both ends in place (even if one end is greased) because it will not be able to slip due to the ridges on the bar. You will need a greased capsule placed on the end of the bar that is intended to slip. You will not have this issue with A36 since it will be a smooth dowel.
A615 can be obtained in smooth or deformed varieties
How about in the other direction? Has anyone ever substituted A36 for F1554 in anchor bolt applications? It's not the preferred material for that application, I realize, but it appears to be allowed per AISC 360, Table 2-6. Has anyone done it and/or know what the real-world implications are?
Archie,
The A307 standard included a Class C which was essentially A36 anchor bolts. So a related question, "Can I use A307-C instead of F1554 Grade 36?"
Ron you are correct. It was a smooth dowel that utilized sleeves on alternating ends to facilitate expansion.
Thanks everyone for the replies! Super helpful!
