What is the best way to approach asymmetric bending forces in wood? For instance, if you have a pitched-roof purlin with the narrow face against the sheathing, such that dimension "d" is not vertical, how do you calculate Fbmax for snow load?
Would you break the vertical load into components perpendicular to the sawn member dimensions, calculate two Fb's, then add them together for a combined Fbmax at the most extreme fiber, which is at the vertex of the two member faces?
