Automate Data Collection
JPArnett
New member
Apr 28, 2023
I would like to automate the task of calculating the mass and center of gravity for a model while varying a dimension over a range of values. Where do I start with this task and what tools should I use? I have an expression driven model with measurement expressions for the mass and center of gravity. I just need a way store the values to a table and iterate the dimension over a range.
 https://files.engineering.com/getfile.aspx?folder=b6fcbaf5-1f19-4560-ad62-1e1249c010b0&file=ExampleForMassData.prt
Thank you so much!! This was my first day using NX journals and I cant believe I actually did it. The thread you shared was exactly what I needed.
I made a small changes. Each iteration now prints all the named expressions on a single line.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
Sub Main()
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim workPart = theSession.Parts.Work
    Dim theUI As UI = UI.GetUI()
    Dim lw As ListingWindow = theSession.ListingWindow
    Dim ResultString As String
    Dim ValueString As String
    Dim HeaderString As String
    Dim i As Integer[/indent]
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "NXJ vary expression")
        lw.Open()
        'Change the values of the following constants to suit your needs
        '  specify expression name in .prt file that references
        '  spreadsheet value
        Const expressionName As String = "Input_SweepAngle"
        Const measureExpressionName As String = "Result_Mass_Lbs"
        Const startValue As Double = 1
        Const endValue As Double = 22
        Const stepValue As Double = .5
        lw.WriteLine("")
        lw.WriteLine("")
        lw.WriteLine("ExpressionToVary: " & expressionName & ", StartValue: " & startValue & ", EndValue: " & endValue & ", StepValue: " & stepValue)
        Dim theExpression As Expression
        Try
            theExpression = theSession.Parts.Work.Expressions.FindObject(expressionName)
        Catch ex As NXException
            If ex.ErrorCode = 3520016 Then
                'no expression found with given name
                lw.WriteLine("expression '" & expressionName & "' not found, journal exiting")
            Else
                lw.WriteLine(ex.ErrorCode & ": " & ex.Message)
            End If
            Return
        End Try
        Dim measureExpression As Expression
        Try
            measureExpression = theSession.Parts.Work.Expressions.FindObject(measureExpressionName)
                lw.WriteLine("expression '" & measureExpressionName & "' not found, journal exiting")
            Else
            End If
            Return
        End Try
        Dim currentValue As Double = startValue
        Dim newFormula As String
        i = 1
        Do While currentValue <= endValue
            'update expression with current value
            newFormula = currentValue.ToString
            'lw.WriteLine("newFormula: " & newFormula)
            theSession.UpdateManager.ClearErrorList()
            Dim markId2 As Session.UndoMarkId
            markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Expression edit")
            theExpression.RightHandSide = newFormula
            Dim nErrs1 As Integer
            'update model
            Try
                nErrs1 = theSession.UpdateManager.DoUpdate(markId2)
                lw.WriteLine("** Update Error with value: " & currentValue.ToString)
                lw.WriteLine("** " & ex.ErrorCode & ": " & ex.Message)
                lw.WriteLine("")
            End Try
            'Write all expressions
                ResultString = i
                HeaderString = "Count"
                ValueString = ""
                ' Loop over each expression in the collection
                For Each myExp As Expression In workPart.expressions
                    ' Check if the name starts with "p"
                    If myExp.Name.StartsWith("p") Then
                        ' Skip this expression and move on to the next one
                        Continue For
                    End If
                    'store expression value
                    ValueString = myExp.Value
                    'Check for scientific notation and convert if needed
                    If instr(ValueString, "E") then ValueString = myExp.Value.ToString("F15")
                    'Add value to result list
                    ResultString = ResultString & ", " & ValueString
                    HeaderString = HeaderString & ", " & myExp.Name
                Next myExp
                'Write Header for the first part loop
                if i = 1 then lw.WriteLine(HeaderString)
                'Write all named expressions
                lw.WriteLine(ResultString)
            'update current value
            currentValue += stepValue
            i += 1
        Loop 'Next Iteration
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
