Automatic Opening Umbrella Operated by Push Button on the Bottom of the Handle
DistressedNerd
45
If you can help me solve this problem I will name my pet chinchilla after you.
I am incorporating a similar locking mechanism to that found in an automatic opening umbrella that unlocks with push of button, the catch is that I need a umbrella in which the push button is in the same line of travel as the collapsing shaft - in other words I need a automatic opening umbrella operated by push button located on the bottom of the handle - not the side as shown in the attached picture.
Have you heard of cams?
dvd - thank you I will be able to complete a functional prototype, however it would be great to have a similar mechanism (see quick video demonstration "Link" and picture) that's not $25 a pop and could be viably mass manufactured. Any recommendations?
Link
If you cannot extrapolate from the quick release pin to what you need, then I probably can't help you.
Why are you trying to reinvent the wheel?
