Automation Scope Table
var10
IN
I want to make a movement table for a scope. I basically just want two axis movements, one in Z (vertically) and one in Y (Horizontally perpendicular to the user), don't need X movement.
Z movement = 80mm so 40mm up & 40mm down.
Y Movement = 40mm so 20 left & 20 right.
Just wondering are there any off shelf mechanism with motors or actuators and a table (150mm x 150mm square) that I can buy?
The weight on them will be around 15-20 kg and with a SF of 4 they will be about 80kg. The space is a bit tight as above, if nothing works out I am going to use some gears and motors and make the table (hopefully not too expensive).
Any suggestions and advice would be great.
Thanks asimpson. I had a look in those websites. They are a little big.
So I think I am gonna have to make something.
