Auxetic material modeling in abaqus
arya1996
21
Hi everyone,
Is there any Plugin available for modeling Auxetic material in abaqus?
If not, what is the way of modeling auxetic without subroutine?
By the way, thanks for answering
There is a plug-in for that, it's named PyAuxetic. You can find its open-source version on github. There's also a paper related to this plug-in: "An Abaqus plugin for evaluation of the Auxetic structure performance" by A.R. Sangsefidi et al.
However, this plug-in just makes it easier to model auxetic structures (re-entrant or chiral/anti-chiral). It's still possible to create them without any add-ons. And you can even perform simulations on simplified homogenous models were auxetcity is induced by specifying negative Poisson's ratio in material properties.
But I have another problem which is, I don't know how to model a negative Poisson's ratio. I mean I'm not sure whether abaqus accept it or not,
because I am not familiar with subroutine writing and I searching for a simple way of defining negative Poisson.
So after all, can you suggest me a simple way of defining this material?
I'll be thankful of your help
You can input negative Poissons’s ratio, in Abaqus it will work. Give it a try.
And if you want to model auxeticity caused by shape, not material, then draw the structure and assign regular material (like steel) with positive Poisson’s ratio to it.
