camel7
- Jan 30, 2012
- 9
Hi
I am working on A steel column which is supported on a steel beam. The steel column is having compression load of 550KN with no moments. For designing the base plate do I need to check for the base plate thickness? When I calculate baseplate thickness based on equation tmin = L* SQRT (2 PU/(0.9FY BN) the thickness comes quite big and I dont see a reason why I need to provide thicker plate is it fair enough to use just use a nominal 12mm or 10 mm plates?
hope to hear from you guys...
cheers
camel
cheers
camel
