I dug through many old threads hunting for the best path forward to handling inspection for B16.5 blind flanges, and can't find any solid recommendations. I'll lay out the issue, and provide some discussion, but I would love to hear how you all approach this issue.
When blinding a standard B16.5 flange, it is normal to just grab a standard B16.5 blind flange. This is done without a second thought, and life moves on.
When considering long-term inspection however, things get more complicated. ASME B16.5 is nearly silent on the topic of corrosion. The thickness of a blind flange in B16.5 is depicted as being exclusive of the raised-face, and paragraph 6.3 states you are allowed to remove the raised-face to create a flat face flange. This leads me to believe the corrosion allowance would equal the height of the raised-face (1/16" for CL150/CL300, and 1/4" for CL600->CL2500). Many times however, I see manufacturer's supplying a standard CL150 or CL300 B16.5 blind flange for manway covers, even when the corrosion allowance on the vessel is specified as 1/8".
Fast forward to on-site inspection. When monitoring the thickness of a blind flange, what is the best practice for specifying a t-min?
I see two valid approaches:
[ol 1]
[li]Set t-min equal to tf from the B16.5 code. Essentially this means the corrosion allowance becomes the height of the raised face.[/li]
[li]Set t-min equal to the thickness obtained by performing an ASME VIII-1 calculation. This will be specific to every vessel as it would take into account the vessel MAWP, temperature, and gasket selection. As many of us know however, many B16.5 flanges fail ASME VIII-1 calculations, so there is a real chance the flange will fail.[/li]
[/ol]
Long story short, what approach do you use in specifying a t-min for B16.5 blind flanges?
[ol 1]
[/ol]
