Back to back FETs
MacGyverS2000
Can anyone think of issues I might encounter by putting MOSFETs back to back (D to S, and S to D, G and G tied together), like an AC switch? When the gate is enabled, I want a signal to pass through this "switch", regardless of which end has the higher potential. I didn't think a single MOSFET would accomplish the goal due to the varying potentials.
As always, replacement circuit suggestions welcome (I'm using SOT-23 packages, so any replacement must be compact).
Same voltage (5V) on both sides, I just mentioned the bus level translators as they would do what I wanted if 5V was provided as the supply for both sides... couldn't find any other transceiver style of component other than bus translators.
I also considered the back to back buffer idea, but couldn't get past they thought of them getting into a race condition of some sort. Connecting the output of buffer 1 to the enable of buffer 2 (and vice versa) seems fine on paper, but real-world components might not like that idea as much. Not to mention one buffer will try to keep the line low/high while a processor down the line tries to drag it in the other direction. Or am I missing the obvious?
I'm missing something. An LVXC4245 would be fine if it was working at 5 volts on both sides? Then why just a regular 245 bidirectional driver can't do the job?
Output of buffer 1 to enable of buffer 2? what do you mean?
Take a look at NC7WZ241. I think it does exactly what you're looking for. If not please explain differently what you're trying to do.
Yes, the LVCX4245 would work fine for this app, if it was significantly smaller... it's an 8-bit transceiver, but I only need 1 channel (I'll accept 2 channel, as the package would probably still be relatively small).
I'm definitely missing the hookup of a dual buffer with output enable, then. Since this is a single wire transmission, the output of buffer 1 needs to hook to the input of buffer 2, and vice versa. Like this:
Code:
At logic 0, we're fine, as both buffers are in a high-impedance state. When a logic 1 (5V) comes down the line, weimmediately run into a snag... a processor will be trying to drive the line high, but so will the opposing buffer. If a 0 is transmitted again, the buffers will continue to drive the line high indefinitely.
The dual active-high/active-low enable operation of the NC7WZ241 doesn't help resolve the issue. A logic 1 will never get through the active-low buffer, and a logic 0 will never make it through the active-high buffer.
Honestly, I'm quite interested in how they make minimal size transceivers (SOT-23) with a minimum of logic gates... seems tricky.
I don't get it. The data controls the tri-state oputput as well?
I don't want it to, but in that configuration it does. I will remove power from the buffers altogether when they're not needed, but otherwise they should be powered and doing their job. It's a two-way communication line that I would like to ensure has enough power... I do not yet know if the edges will need periodic sharpening, so a schmitt trigger input to the buffers is ideal.
At first thought, back to back buffers seems the way to go. Further thought says the input of one needs to tri-state the output of the other. Even further says that just won't work. I was going to post a small mass of gates necessary to make this work, then decided by the time I go through with all of that, the circuit would be quite large.
Luckily enough, this circuit will not need to be used very often, so I can skip populating those pieces on the boards that won't need it. That being the case, I'm leaning towards two possible solutions.
1) A small processor, like a PIC 12F series, with interrupt-on-change capability. It may introduce a minor delay in the signal, but if coded correctly, the delay should be constant. I would have complete control over both sides of the bus, and although I probably wouldn't have Schmitt trigger inputs, the output signals would have sharp edges again. With oscillator and support components, the circuit should be less than $2. Board space should be around 0.5" square, even less if I use both sides of the board (the oscillator will be larger than the processor ;-) ).
2) A small PLD or the like with a setup similar to the above. I don't know if they make PLDs as small (or as cheap) as the PIC mentioned above, but it's worth a shot to look for one. I would need to purchase more programming equipment (that stinks), but there is potential for the unit to be really cheap (only potential, as the cheapest PIC is $0.55!).
I hope you guys don't think I'm being to picky about this stuff. I just want to make sure this circuit works the first time around and do it as inexpensively and in as small a space as possible.
A OTP bipolar fuse PLD should be inexpensive?
TTFN
