delagina
- Sep 18, 2010
- 1,008
I have a construction issue where soil erosion happened under a pipeline.
contractor back filled using cement stabilized fill but just dumped it above the pipeline.
Now we have a huge void under the pipeline that we need to backfill.
removing the backfill above pipeline is not an option anymore per contractor.
what are the best options here.
I was thinking using a hose and pumping flowable cement fill to fill up the void.
what else can you suggest including the type of flowable fill that is best to use in this case.
