mansoor ck
Dear all,
i am having a doubt on base plate connection design. here there is a tube section of (150mm X 100mm x 5mm)is connected to the base plate of 300mm x 200mm . in the design the support is considered as a pin support. in that case whe it comes to the detailing side , " where shall be the location of bolt".
thank you in advance.
