Hi all,
Realize this has been discussed before, I reviewed the threads and can't seem to find a clear answer to this question.
In the case where one has a base plate supported by anchor bolts and leveling nuts lets say the assembly is sitting on an 18" thick footing. Anchor bolts are embedded, lets say 12" into the foundation. Smooth shank A307 bolts with 2 heavy hex. No grout is used.
The contractor is told to crank the leveling nuts to the top of foundation but cannot do so keeping everything level.
When under lateral load there is about 8 kips of compressive force on half the anchor group. Below the footing is a well compacted base.
Looking at the anchor bolts (smooth shank) it doesn't seem like there is going to be much of a bond between the bolt and the concrete. It seems like the axial force will make its way through the bolt shaft and into the head.
How does one get a handle on how much force the anchor bolt can take before it cracks the 6" of foundation left below the head of the bolt?
