palk7 EIT
- May 12, 2020
- 159
I received this detail regarding a staircase opening in basement where the floor joist/ framing does not provide any top support for the basement wall. Under this case I see it more like a cantilever wall, in that case shouldn't the reinforcement be on the other side? as opposed to this dwg. why is it provided on the inside face, is it because the garage slab is considered as lateral support? but there is no positive connection between the slab and the wall and also the slab is on the fill side. Really appreciate your inputs on this.
Thank you
Thank you
