I'm in dire need of assistance in fixing an aircraft sim. I was a Math/Physics major before switching to electrical engineering so I have a good background in the area but could use a true ae to help with some of the areas that are not quite right.
If I adjust the rudder parameter for example to make it turn well, it messes up the behavior for when the plane falls backwards after flying straight up. This makes me believe I'm not doing something right like not modeling the forces on the control surfaces correctly.
I have about 12 steps in my sim process and model about 11 main forces so it's not a very detailed simulation. If anyone has time to help, it would be greatly appreciated. I would be willing to pay for someone's time if that would be appropriate. I'm including a summary of what I do below but let me know what else I should provide.
Reggie
Vector Setup - I don't suspect any problems here, I deal a lot with vectors and these should be correct.
Rotation Slowdown - I reduce any rotation velocities across all 3 axis here to simulate the wind resistance that would slow down a rotating aircraft that was spinning fast. Here's the calc for each axis.
f1 = angularVelocityX * angularVelocityX * 90 // 90 is an arbitrary constant that gave good results. The faster it's spinning, the greater the slowdown torque
// f1 is now checked to make sure it's not big enough to cause a rotation in the opposite direction, ie it can only slow down the current rotation to 0
torqueX = torqueX - Math.Sign(angularVelocityX) * f1
// Repeat for X & Y axis
Elevator Effect - I add in rotation velocity due to the effect of the elevator. I could have set a torque but decided instead to just directly affect the rotation.
velocityUp = plane's velocity perpendicular to the elevator
curTime = 0.001 // I used fixed time steps of 0.001 seconds
signFactor = 1 or -1 depending on the direction of velocityUp
f4 = dot product of velocity with planes forward vector
f4 = Math.Sign(f4) * (1.0f - Math.Abs(f4)) // If velocity is parallel to elevator, f4 is 0. As velocity approaches completely perpendicular to elevator, f4 goes to 1
angularVelocityX += signFactor * velocityUp * velocityUp * f4 * 0.025f * curTime // 0.025 is a scaling factor
Lifting Force from Wings - If the plane's velocity is forwards, I calculate lift and drag forces for each wing so as to take into account the dihedral angle.
velocityF = plane's velocity with side component removed ( only forwards/upwards velocity components remain )
drag = Get_Point_2D_Float_Graph(angleOfAttack, 0) // look up the drag from a lift/drag curve
totalDrag = drag * wingDragFactor * velocityF * velocityF * 0.5f; // Divide by two since this is just half of the wing
forceX -= totalDrag * xForward // Add in drag forces for each axis due to wing drag
forceY -= totalDrag * yForward
forceZ -= totalDrag * zForward
signFactor = 1 or -1 depending on the direction of the angle of attack
lift = Get_Point_2D_Float_Graph(angleOfAttack, 1) // look up the lift from a lift/drag curve
totalLiftRightWing = lift * wingLiftFactor * velocityF * velocityF
forceX += totalLift * signFactor * wingVectorUpX
forceY += totalLift * signFactor * wingVectorUpY
forceZ += totalLift * signFactor * wingVectorUpZ
// Repeat for second wing
Dihedral Torque - I add in torque produced by the wings dihedral angle.
torqueY -= mainVelocity * (totalLiftLeftWing - totalLiftRightWing) * 0.000000005 // Last number is a constant that produced a good result
Rudder
velocityRight = velocity component parallel to the plane's right vector ( as seen from pilot's viewpont )
torqueZ -= Math.Sign(velocityRight) * velocityRight * velocityRight * 0.075f
Engine
forceX += xForward * engineThrust
forceY += yForward * engineThrust
forceZ += zForward * engineThrust
Wind Resistance
f2 = velocityForward * velocityForward * flatPlateArea;
forceX -= f2 * xForward
forceY -= f2 * yForward
forceZ -= f2 * zForward
Force Against Wings - This would come more into play if the plane were dropped with zero velocity
f1 = velocityUp * velocityUp * areaWing;
forceX -= f1 * xUp;
forceY -= f1 * yUp;
forceZ -= f1 * zUp;
Gravity
forceZ += DefinesClass.GRAVITY * mass
Controls Input
// rotZ = rudder input
// rotY = aileron input
// rotX = elevator input
torqueZ -= rotZ * 0.001f * velocityForwards // 0.001f is a scaling factor for the input parameter
torqueY += rotY * 0.00045 * fuselageVelocitySquared // 0.00045 is just a scaling factor for the input parameter
torqueX += rotX * 0.00012 * fuselageVelocitySquared // 0.00012 is just a scaling factor for the input parameter
Calcuatle Position, Velocity, and Rotations - After summing up the forces and torques, I have a basic physics routine that calucates the new state of the aircraft. This is pretty straightforward and I don't believe I have any issues here.
get_Planes_Position(airCraftData, curTime)
Reggie
Rudder
Engine
Wind Resistance
forceX -= f1 * xUp;
forceY -= f1 * yUp;
forceZ -= f1 * zUp;
Gravity
Controls Input
