Hi Team,
I have just been brushing up on my structural analysis. I picked an example problem from a text book to draw a BMD and SFD.
This is the problem I picked:
I undertook a hand calculation as follows:
I am confident the solution is correct but thought of double checking it in a modelling software (Strand7). I have not used strand7 before and its a bit of a learning curve. I have used SpaceGass in the past but I don't have access to that software.
I modelled the problem like this:
When I ran it I got an error - "Singular Matrix". I knew immediately that the issue must be the two ends that I have released rotationally. I released them cause I wanted to mimic a pin connection as the question asks. If I remove the rotational release, the model works and produces an output. So I know for sure it is that pin connection that is causing the analysis to halt.
What am I doing wrong in the model? The way I have modelled it with that pin connection is probably forming a mechanism.
Any thoughts and advice please as to where I could be going wrong?
