Basic CATIA VBA question
Andzejus
Industrial
Oct 19, 2015
16
LT
I'm trying to learn how macros work in CATIA (3DEXPERIENCE R2016x).
I started recording VBA macro (in generative shape design);
Selected xy plane, started a sketch,
drew a circle with radius 3,
exited sketch and used volume extrude with dimension 1.
Then I stopped recording.
Now when I try to play this macro, it gives me an error:
"Run time error '91':
Object variable or With block variable not set"
What is causing this error? I don't think I made something fancy,
and it already throwing errors at me.
Here is the code:
Code:
Sub CATMain()
Dim vPMRepReference1 As VPMRepReference
' No resolution found for the object vPMRepReference1...
Dim part1 As Part
Set part1 = vPMRepReference1.GetItem("Part")
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item("Geometrical Set.4")
Dim sketches1 As Sketches
Set sketches1 = hybridBody1.HybridSketches
Dim sketch1 As Sketch
Set sketch1 = sketches1.Item("Sketch.4")
part1.InWorkObject = sketch1
Dim factory2D1 As Factory2D
Set factory2D1 = sketch1.OpenEdition()
Dim geometricElements1 As GeometricElements
Set geometricElements1 = sketch1.GeometricElements
Dim axis2D1 As Axis2D
Set axis2D1 = geometricElements1.Item("AbsoluteAxis")
Dim line2D1 As Line2D
Set line2D1 = axis2D1.GetItem("HDirection")
line2D1.ReportName = 1
Dim line2D2 As Line2D
Set line2D2 = axis2D1.GetItem("VDirection")
line2D2.ReportName = 2
Dim circle2D1 As Circle2D
Set circle2D1 = factory2D1.CreateClosedCircle(0#, 0#, 3#)
Dim point2D1 As Point2D
Set point2D1 = axis2D1.GetItem("Origin")
circle2D1.CenterPoint = point2D1
circle2D1.ReportName = 3
Dim point2D2 As Point2D
Set point2D2 = factory2D1.CreatePoint(3#, 0#)
point2D2.ReportName = 4
Dim constraints1 As Constraints
Set constraints1 = sketch1.Constraints
Dim reference1 As Reference
Set reference1 = part1.CreateReferenceFromObject(circle2D1)
Dim reference2 As Reference
Set reference2 = part1.CreateReferenceFromObject(point2D2)
Dim constraint1 As Constraint
Set constraint1 = constraints1.AddBiEltCst(catCstTypeOn, reference1, reference2)
constraint1.Mode = catCstModeDrivingDimension
Dim reference3 As Reference
Set reference3 = part1.CreateReferenceFromObject(point2D2)
Dim reference4 As Reference
Set reference4 = part1.CreateReferenceFromObject(line2D1)
Dim constraint2 As Constraint
Set constraint2 = constraints1.AddBiEltCst(catCstTypeOn, reference3, reference4)
constraint2.Mode = catCstModeDrivingDimension
Dim reference5 As Reference
Set reference5 = part1.CreateReferenceFromObject(circle2D1)
Dim constraint3 As Constraint
Set constraint3 = constraints1.AddMonoEltCst(catCstTypeRadius, reference5)
constraint3.Mode = catCstModeDrivingDimension
Dim length1 As Length
Set length1 = constraint3.Dimension
length1.Value = 3#
sketch1.CloseEdition
part1.InWorkObject = hybridBody1
Dim settingControllers1 As SettingControllers
Set settingControllers1 = CATIA.SettingControllers
Dim settingRepository1 As SettingRepository
Set settingRepository1 = settingControllers1.Item("LPCommonEditor")
boolean1 = settingRepository1.GetAttr("LowLightMode")
part1.Update
Dim hybridShapeFactory1 As HybridShapeFactory
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim hybridShapeDirection1 As HybridShapeDirection
Set hybridShapeDirection1 = hybridShapeFactory1.AddNewDirectionByCoord(0#, 0#, 0#)
Dim reference6 As Reference
Set reference6 = part1.CreateReferenceFromObject(sketch1)
Dim hybridShapeExtrude1 As HybridShapeExtrude
Set hybridShapeExtrude1 = hybridShapeFactory1.AddNewExtrude(reference6, 1#, 0#, hybridShapeDirection1)
hybridShapeExtrude1.Context = 1
hybridShapeExtrude1.SymmetricalExtension = 0
hybridBody1.AppendHybridShape hybridShapeExtrude1
part1.InWorkObject = hybridShapeExtrude1
part1.Update
End Sub
Fifth line is the one that generates error:
This is what I have in 3DEx 2017x cloud. Should work also in 3DEx 2016.
L'm starting from here
Code:
Sub CATMain()
Dim editor1 As Editor
Set editor1 = CATIA.ActiveEditor
Dim part1 As part
Set part1 = editor1.ActiveObject
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")
Set sketches1 = body1.Sketches
Dim axisSystems1 As AxisSystems
Set axisSystems1 = part1.AxisSystems
Dim axisSystem1 As axisSystem
Set axisSystem1 = axisSystems1.Item("Absolute Axis System")
Set reference1 = part1.CreateReferenceFromBRepName("FSur:(Face:(Brp:(AxisSystem.1;2);None:();Cf11:());WithPermanentBody;WithoutBuildError;WithInitialFeatureSupport;MonoFond;MFBRepVersion_CXR15)", axisSystem1)
Set sketch1 = sketches1.Add(reference1)
Dim arrayOfVariantOfDouble1(8)
arrayOfVariantOfDouble1(0) = 0#
arrayOfVariantOfDouble1(1) = 0#
arrayOfVariantOfDouble1(2) = 0#
arrayOfVariantOfDouble1(3) = 0#
arrayOfVariantOfDouble1(4) = 1#
arrayOfVariantOfDouble1(5) = 0#
arrayOfVariantOfDouble1(6) = 0#
arrayOfVariantOfDouble1(7) = 0#
arrayOfVariantOfDouble1(8) = 1#
Set sketch1Variant = sketch1
sketch1Variant.SetAbsoluteAxisData arrayOfVariantOfDouble1
Set circle2D1 = factory2D1.CreateClosedCircle(0#, 0#, 84.852814)
Set reference2 = part1.CreateReferenceFromObject(circle2D1)
Set constraint1 = constraints1.AddMonoEltCst(catCstTypeRadius, reference2)
Set length1 = constraint1.Dimension
length1.Value = 84.852814
part1.InWorkObject = body1
part1.Update
boolean2 = settingRepository1.GetAttr("DisplayRequirementsMode")
Dim shapeFactory1 As ShapeFactory
Set shapeFactory1 = part1.ShapeFactory
Dim pad1 As Pad
Set pad1 = shapeFactory1.AddNewPad(sketch1, 20#)
part1.Update
End Sub
Fernando
- Romania
- EU
Hello ferdo,
Thank you for your reply.
I've tested your code on my 3DEx 2016- in generative shape design.
And in my colleagues's 3DEx 2016- in part design.
In both cases it gives the same errors.
Maybe it is because you used catvba?
I don't have catvba option for some reason,
so I used your code with VBA and with CATscript,
and it gives error on different line.
We will be upgrading to 3DEx 2017 soon,
Perhaps I'll just need to wait to find out if different versions is the reason why it doesn't work.
I thought you used catvba (vba is written in your code header). VBA from Excel? Or?
Of course the code will look different in CATScript. Can you give more details where are the errors?
Ask your IT to install vba for CATIA, I saw many companies which are not using just because they consider is an security issue...but why then let Office VBA?
Fernando
- Romania
- EU
When I create macro library I have 2 options:
-PLM Directories;
-PLM VBA Directories
If I choose PLM VBA, then macro langiage is "MS VBA",
If I choose PLM Directories, then macro language is "CATScript"
I chose MS VBA because I thought I could try to transfer data from CATIA to EXCEL later.
1 In generative shape design I go to Tools > Macros.
2 I create new macro with MS VBA language. Then I hit 'Edit' and paste your code in a window that appears (the same window is shown on image 4).
3 Then I run this macro and get this error message.
4 When I press 'Debug' I can see a line where error is generated.
Look at the picture please. When you start to run the macro you need to have already created an axis system, this is how I setup my starting 3D Shape. In 2017x when you want to create a 3D Shape it will be inserted directly under a physical product, that's a difference between 2016 and 2017 if I remember correctly.
Fernando
- Romania
- EU
Thank you for showing my error.
Now macro works, but only partially:
It creates a sketch and then stops on this line:
Yes, now that sketch was extruded and macro finished without errors.
thank you for your patience.
