benensky
- Dec 15, 2003
- 14
I am new to ISO drawing and have a question on dimensioning holes. What standard do you use? Granted I could purchase the, "ISO Standards Handbook - Technical drawings" but it is expensive and has standards I will not use and do not need. I am asking for guidance on the ones I will use.
I have bought a couple books on ISO drawing and have gotten conflicting information. Therefore, I need to buy the standards to see for myself.
One situation I have is holes on a bolt circle. Do you call out the hole and the bolt circle diameter separately or can you call it out all in one note. Please do not tell me what you do. I would like to know the standard you reference for this.
A second situation is that of counterbores and countersinks. ANSI has shifted to symbols for this and what I understood is that ANSI was shifting to symbols to be more like the ISO standard so that eventually one day the standards for technical drawing will be identical. In Simmons & Maguire’s book Manual of Engineering Drawing to British and International Standards they still use the truncated words C’Bore and C’SK. Another book I purchased, Paul Green’s Mechanical Engineering Drawing Desk Reference; Creating and Understanding ISO Standard Technical Drawings does not use symbols or truncated words but dimensions the diameter of the counterbore and depth and separately dimensions the hole. In the Technical Drawing section of the Lehrmittle Europa Technical Book Series Mechanical and Metal Trades Handbook (the book that the German company that owns us and requires us to draw to ISO standards gave us to use as a guideline) has an abbreviated way of calling out countersinks. For example, you could call out a countersink by putting this at the end of a leader which points to the countersink, “Ø10x14U”, where 10 is the diameter of the hole and 14 is the depth. However, I noticed that that is to DIN 6780 which is not an ISO standard. From what I can tell, this method will not be recognized universally by all people using ISO standards. Does anyone know what ISO standard defines how to dimension counterbores and countersinks?
I have more questions but I will ask them later in the thread if I get some good feedback.
