I am doing a switch mode lead acid battery (12v) charger with UC3909 IC
Datasheet:-
The circuit i am using is like page 7 on the datasheet.
I am trying to incorporate reverse polarity protection for when the battery is connected the wrong way round into the charger...
-i wish it to do the following when reverse polarity...
1. Shut off current flow from charger to battery.
2. Reverse polarity protection components should not provide a discharge path for the battery when the charger is switched off (when battery connected right way round)
3. LED lights when battery is in wrong way round.
.....i don't think there would ever be a short circuit current if wrong-way-round battery connection is done....this is because pin 10 of UC3909 would experience a low voltage (?) and so will go into trickle charge mode (just supplying a few mA max.).....however, i still wish to manage the situation and shut off current flow to the battery if its in wrong.
Here is my proposed reverse polarity protection circuit:-
..Do you believe this will work?....i am worried that the 30V input may somehow be felt at the battery negative terminal and keep mosfet 2N7000 ON...thus not allowing Q3 PFET to disconnect the battery?
Datasheet:-
