dgallup
Automotive
- May 9, 2003
- 4,715
I've got a part with a bayonet feature on one end that another part will lock into. I'm not sure what is the best way to ensure proper position of these features to the ID bore and to each other. The mating part will slide in the bore and have a cross pin that has to slide in the slot on both sides and then rotate 45 degrees to hold the two parts together. The most important dimension is the the bottom surface of the locking lug because that will control squeeze on a seal. I want that directly toleranced from the opposite end but maybe the rest could just be a profile control? But there has to be something controlling the 180 degree symmetry between the two lugs.
