EntryLevelEIT
- Jun 24, 2010
- 42
In beams analysis, if the compression reinforcement does not yield, does the beam then get analyzed as if it has tension reinforcement only?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The nominal moment capacity Mn for the assumed strain distribution is found by summing the moments of all the internal forces about the centroid of the column. The moments are summed about the centroid of the section, because this is the axis about which the moments are computed in a conventional structural analysis. In the 1950s and 1960s, the moments were sometimes calculated about the plastic centroid, the location of the resultant forces in a column strained uniformly in compression. The centroid and plastic centroid are the same point in a symmetrical column with symmetrical reinforcement
