EntryLevelEIT
- Jun 24, 2010
- 42
In beams analysis, if the compression reinforcement does not yield, does the beam then get analyzed as if it has tension reinforcement only?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The calculated capacity would have something to do with your code, but csd acknowledges that the actual capacity is not reduced.In a very lightly loaded beam, taking the compression reinforcement into account may actually reduce the calculated moment capacity (but not the actual capacity).
without even going into the technical details, common sense says that adding more reo to the compression face of a beam will not make it weaker
As this thread seems to be mostly based on opinion then I suppose it is up to me to drag it back to the facts.
I have double checked my theory using a spreadsheet based on british standards and have confirmed that it is correct to that code. So I stand by my comments as valid.
As most of the people on this thread are based in the US then I will try and do my proof calcs to ACI code but I will have to wait until I am at home and can access my pdf copy
I am working from home today so am not able to scan the calcs in.
