BEARINGS TYPE FOR BB3 PUMPS
Samingme755
19
hi
im asking about the selection of bearing for bb3 pumps and whats standards do i need to follow to chose between sleeve bearings and ball type bearings
thanks
Hello Samingme755,
For BB3 type axially split multi-stage centrifugal pumps, one of the industry standard is API 610.
The bearing selection mainly depends on factors such as pump speed (RPM), horse power, mean bearing diameter, desired bearing life, etc etc.
Here is "Table-9 Bearing selection" from a copy of API 610 that you can use as a reference to start. Good luck with your research!
Why not consult the manufacturer / representative, better than an open ended dataless question.
are you trying to design new pump? or are selecting a pump for a project?
As Dynamics Eng has pointed out, API610 is your guide.
Since you refer to it as a BB3 pump, that implies API610 is your reference, so I suggest you read it, as it tells you exactly what to do.
