I often need to know mass flow rate through air cooled industrial equipment and usually struggle to get repeatable measurements using vane or hot wire anemometers. I can only measure at the intakes, which are up to 700mm (~28") sq with flow in the 1500 to 5000 CFM range. Fan pressure is usually around 200-300Pa.
What methods or equipment are most accurate for measurements like this? Set-up time and cost aren't big concerns as much as getting measurements with a known accuracy (is 5% asking too much?).
All suggestions/comments appreciated.
Jon C
Jon C
