Best o ring material for marine heat exchanger 1
MBam
Marine/Ocean
I am looking for a recommendation re the best O ring material to use in a marine heat exchanger.
The liquids are sea water and antifreeze (50% ethylene glycol/water). Normal temperature is 180F with 230F maximum.
The problem that currently exists is that the o rings take a set and start to seep. Once that happens the aluminum housing corrodes and damages the copper cooling bundle. At this time I don't know the assembled dimensions as the one housing I have is too corroded to measure. I will have another one later today.
I don't know what the existing material is however the manufacturer specifies a 24 month replacement interval. Given the amount of work involved in changing them out the actual cost of the o ring is probably not a factor.
Thanks!!
 https://files.engineering.com/getfile.aspx?folder=b463d20f-6df7-4ce9-922c-afd47b6cf10a&file=heatExchanger.pdf
EPDM would be the material of choice for water and water with anything that dissolves in it. 70 durometer EPDM is fairly standard, set-resistant stuff. The peroxide-cured epdm's are a bit more set resistant, and cost a bit more.
Oh, just one thing - never let standard petroleum products (oil, grease, fuel) get on epdm, it will soften and swell. If you need a lubricant for installation, use silicone grease, or plain old soap and water, or water and glycol.
Thank you!
I'm getting ready to machine the damaged housing and put in a sleeve to restore the surface. I am trying to decide on aluminum or bronze. I am thinking bronze will be better.
See photo.
 https://files.engineering.com/getfile.aspx?folder=2e1963ed-b0fc-4477-a0ab-bf3d630e1228&file=heatexchanger1.jpg
You may have other problems.
If you allow sea water to get hotter than ~140F, the salt will plate out on all metal surfaces, and eventually clog the pipes.
You may need bigger heat exchangers and higher seawater flows.
Mike Halloran
Stratford, CT, USA
