Best Stainless Steal for high temperatures and oxidative environment
Brodusch
Industrial
Sep 27, 2013
4
I have a very specific application at high temperature (900C) in a very high oxydative atmosphere, in copper industry. We use the 310 for decades and it seems the best SS for this. Do you know if there is a possible alternative in stainless steels with higher resistance to oxidation, better than the 310? Does the 310L should be best than 310?
I read different topics, 310 stainless steel is largely used for high temperature applications in metallurgy processes, 316 being a possible alternative (lower Cr amd Ni but low C), 309? 409?
Thank you in advance for your help and advises.
________________________
Ludovic Brodusch
Metallurgy Ing.Jr. M. Sc. A.
Montreal, Canada
Ludovic,
You may explore Outokumpu/Sandvik-353MA for such high temp service in highly oxidising environments.All these manufactures are well represented in Canada.
See the datasheets below.
Thanks.
Pradip Goswami,P.Eng.IWE
Welding & Metallurgical Specialist
Ontario, Canada.
ca.linkedin.com/pub/pradip-goswami/5/985/299
there are a lot of high temp alloys.
Is oxidation the only degradation mechanism?
310 will be clearly superior to 316, 309, and low Cr ferritics like 409.
You can get a little improvement with a high Cr ferritic like 439.
In order to see significant improvement you will need to look at alloys like 600, 601, 333 and other Ni based alloys.
Plymouth Tube
Thank you for these very usefull information.
Yes the main degradation mecanism is oxidation (1000C, not dry - burner flamme + O2 addition).
Do you know where I could find comparative data for the 439, 446, 600, 601, 333?
I was told the 436 could be an alternative? What do you think?
_____________________________
Ludovic Brodusch , Ing. Jr. M. Sc. A.
Montreal, Canada
You need a couple of books.
A good place to start is "High Temperature Corrosion of Engineering Alloys, George Lai, ASM, ISBN:0-87170-411-0
Plymouth Tube
Fecralloy and Nicralloy have very high oxydation resistance at 1000C.
