Best way to check connected curves ?
lexus911
Automotive
VN
Hello!
I have a pretty basic question.
I am trying to write a macro to check connected curves in the model, the old way to check is using the project curve feature and select a connected curve. it takes a lot of time if I have many curves.
can you help me another way to improve it
Knowing what version of NX you're using would be quite helpful.
Tim Flater
NX Designer
NX 11.0.2.7 MP11 Rev. A
GM TcE v11.2.3.1
GM GPDL v11-A.3.5.1
Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
Are you working with edges on a body? If so, the .AskCnncEdges method might be helpful. It appears that it will only work with edges and won't accept curves (lines, arcs, splines, etc) as input.
www.nxjournaling.com
Thanks @Cowski ,i will try it
I tried, but it not work, can you help me fix my code, Thanks
I tried to write a demo code, change the color of the connected curve
Code:
using System;
using NXOpen;
using NXOpen.UF;
public class NXJournal
    static Session theSession = Session.GetSession();
    static UFSession theUFSession = UFSession.GetUFSession();
    static Part workPart = theSession.Parts.Work;
    public static void Main(string[] args)
		Curve[] theCurves = SelectCurves("Select connected curves");
        if (theCurves.Length == 0) return;
        System.Collections.Generic.List<Curve>[] sortedCurves = sort_by_connectivity(theCurves);
		DisplayModification displayModification1;
        displayModification1 = theSession.DisplayManager.NewDisplayModification();
        displayModification1.ApplyToAllFaces = false;
        displayModification1.ApplyToOwningParts = false;
        displayModification1.NewColor = 11;
        displayModification1.Apply(sortedCurves);
        displayModification1.Dispose();
    static System.Collections.Generic.List<Curve>[] sort_by_connectivity(Curve[] theCurves)
        NXOpen.Session.UndoMarkId markId1;
        markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "");
        System.Collections.Generic.List<Tag> theCurveTags =
            new System.Collections.Generic.List<Tag>();
        foreach (Curve aCurve in theCurves) theCurveTags.Add(aCurve.Tag);
        int n_joined;
        Tag[] joined = new Tag[theCurveTags.Count];
        theUFSession.Curve.AutoJoinCurves(theCurveTags.ToArray(), theCurveTags.Count,
            2, joined, out n_joined);
        System.Collections.Generic.List<Curve>[] CurveLists =
            new  System.Collections.Generic.List<Curve>[n_joined];
        for (int ii = 0; ii < n_joined; ii++)
            CurveLists[ii] = new System.Collections.Generic.List<Curve>();
            double min_dist;
            double[] junk = new double[3];
            double accuracy;
            int which = 0;
            theUFSession.Modl.AskMinimumDist3(2, joined[0], aCurve.Tag, 0, junk, 0, junk,
                out min_dist, junk, junk, out accuracy);
            for (int ii = 1; ii < n_joined; ii++)
                double this_dist;
                theUFSession.Modl.AskMinimumDist3(2, joined[ii], aCurve.Tag, 0, junk, 0, junk,
                    out this_dist, junk, junk, out accuracy);
                if (this_dist < min_dist)
                    min_dist = this_dist;
                    which = ii;
            CurveLists[which].Add(aCurve);
        theSession.UndoToMark(markId1, "");
        theSession.DeleteUndoMark(markId1, "");
        return CurveLists;
    static Curve[] SelectCurves(string prompt)
        TaggedObject[] selobjs = null;
        Selection.Response resp =
            UI.GetUI().SelectionManager.SelectTaggedObjects(prompt, "Select Curves",
            Selection.SelectionScope.WorkPart, false,
            new Selection.SelectionType[] { Selection.SelectionType.Curves },
            out selobjs);
        System.Collections.Generic.List<Curve> theCurves =
        foreach (TaggedObject aTO in selobjs)
            if (aTO is Curve) theCurves.Add((Curve)aTO);
        return theCurves.ToArray();
    public static int GetUnloadOption(string arg)
        return System.Convert.ToInt32(Session.LibraryUnloadOption.Immediately);
