blevins solution for centre pivot beam 1
greyspace
Automotive
GB
I have a rocker ohv shaft supported by 3 springs. The first is the pushrod stiffness, the third is the valve stem stiffness and the second is the rocker shaft reaction point. The rocker pivots about this centre point. When I try to calculate the natural of the assembly, I get an incorrect answer, I think I incorrectly omit the rigid body rotation effect. Blevins (Book - Formulas for frequency and mode shape) I recollect has the solution for the natural frequency for this system. Anybody got the book and tell me what the closed form solution is?
k1 k2 k3
|---a-----|------b------|
note a and b are distances k1,k2,k3 are the spring stiffnesses with the rocker pivoting about k2 position. m1,m2,m3 not shown but go with k1,k2,k3.
If the pivot is fixed, it is effectively infinitely stiff.
Then the rotational natural frequency about 2 is:
f = sqrt[(k1.L12^2 + k3.L23^2)/(m1.L12^2 +m3.L23^2)] /2/pi
where
L12 = distance from 1 to 2
L23 = distance from 2 to 3
m1 = mass at 1
m3 = mass at 3
f = frequency
masses in kg, lengths in metres, frequency in Hz (or use another coherent system of units - but I recommend metric SI).
