Bluebeam pdf resets my drawing orientation?
rossao1
11
Hi all,
Here is the problem. SW2003 sp5.1 with blue beam pdf creator (bbpc) sp 2.2.1 . After I use BBPC my drawing is re-oriented into the "portrait" not the "landscape" that I want. It keeps doing this and I can not stop it. I have to reset my orientation every time before printing the file from SW back to landscape. BTW my drawings from BBPC come out with the "Landscape" orientation, just like I want.
Help me please. Thanks in advance.
A-
Did you try "file, page setup, change the orientation" then save the file?
Ok, tried that. No difference. The orientation changed from landscape to portrait again.
Also I am using "use document settings" and "scale sheet to fit paper" on the "page set up" page.
A-
Bluebeam is one of the worst things to come down the pike. Not only did I have similar problems but they migrated to my full blown Acrobat. I turned the add-in off and deleted the Bluebeam printer entry and all is well again.
King of makes me wonder if Bluebeam might be spyware as well!
I have the same problem as well. Should make an enhancement request to Bluebeam I suppose. They have been very accommodating to me so far. But I must say I haven't seen the problems migrate to Acrobat. Which problems are you seeing Mandrake22?
The main problem was the inability to print in landscape format, regardless of settings. This was occurring in a normally functional install of Adobe 6, well at least it was prior to Bluebeam.
I have submitted a request for assistance to Blue Beam. I will let y'all know how it turns out.
A-
Hi all,
It seems that the problem was diagnosed to be a SW issue. They tested it with BlueBeam installed and NOT installed. The problem remained. It seems to have something to do with changing printers, and the settings don't return correctly.
I will sumbit Bluebeams response to SW as a enhancement request. (who knows.. it may already have been addressed.)
I have a work around. Path of least resistance... By setting a key board shortcut to "print preview" as "shift-p", and doing a double return key to accept it, I can "see" if there is a problem before printing. It is crude but works well.
A-
