Daren Samy
- Oct 6, 2022
- 59
We have experienced increased water content in lube oil of main feed water pump. This lube oil is supplied by shaft mounted main oil pump from lube oil tank to bearings of main boiler feed water pump and main boiler feed water booster pump. Both pump are coupled in series by motor and reduction gear.In lube oil tank, heater remains off and there is no provision of silica jel damp removers. During first operation, water contents remain with in range. But when it is taken out of service, water contents start to build up. Consequently, I have to remove oil cooler to perform hydrostatic rest. Hydrostatic test is qualified. I am clueless about water ingress. What can be reason ?
Daren!
Daren!
