jondon
- Jul 10, 2014
- 12
I have a question regarding bolt preload and the resulting bolt "load factor".
I am designing a bolted connection for a cargo crane foundation on a large marine vessel. We are limited to a 1" bolt diameter by the crane vendor's bolting flange design, and we would prefer to use stainless steel bolts for the connection because of the marine environment. My calculations show that, under the applied crane proof test load, our chosen 1" 316-SH stainless bolts (proof stress 63,000 psi, yield stress 70,000 psi) have a bolt "load factor" of 0.79 when torqued to the typically recommended value of 75% of yield. Most of my references indicate that the designer should shoot for a "load factor" of 1.0 or greater to ensure that the bolt load does not exceed the proof load.
My main question is this: given that bolt size and material grade are fixed, can we back off on the specified bolt torque to reduce the bolt stress below the proof stress, so long as the final bolt load is adequate to prevent separation of the bolted flanges?
Many of the references I have come across suggest that bolts be torqued to 90% of yield, or even to the yield point, to create an efficient tension joint, but this would seem to contradict the general design practice of keeping the bolt "load factor" below 1.0. Can someone help clarify?
For reference, I am calculating the bolt "load factor" as n=(Sp*At-Fi)/(C*P), where:
n = load factor (to be greater than 1.0)
Sp = bolt proof strength
At = bolt tensile-stress area
Fi = bolt preload
C = joint stiffness constant
P = external tensile load
Fi = bolt preload
