Bolt Torque and Bolt preload query
Danmecheng
1
Hi All,
Currently going through a series of HX to calculate and verify torque values for girth flanges for an upcoming shutdown and pretty much doing a quick design sense check using the Appendix 2 calcs to determine the design minimum then following the guidance in PCC-1 appendix J , K and O to get the final assembly values. However when calculating the bolt preload to ensure the integrity of the bolts i.e. (tensile stress area x % utilisation x Minimum yield strength) can I ask for the yield strength value do you all normally use the yield strength for the bolt based at ambient temperature conditions or operating temperature conditions ?
I know standard practise is to applying between 40-70% yield and I like to use a utilisation of minimum 50% Yield but if you look at some of the exchangers the operating temp can be nearly 500°C so quite a difference in yield values compared to that of ambient condition so I assume it would be best to use operating conditions as to not over stress the bolt when it reaches its operational temp
This has caused abit of discussion in the office and keen to hear your thoughts on this and what you normally do ? I quite often use table Y1 of BPVC Section 2D to obtain the yield values at operating temps and find it quite good for this ?
Cheers
Dan
Be careful with this video: studs are not mentioned.
I've never used bolts on pressure vessels; I use studs.
There are many examples using bolts on block flanges (Figure UG-34 (p), Figure UG-40 (a-1), (a-2)): INCORRECT
Please explain thank you
From my under standing if the % of accuracy of torque to obtain preload is acceptable its good.
If more accuracy then inspect elongation with ultrasonic for the delta change of length.
And obtain a more accurate measurement.
I have experience with ultrasound and it can get touchy with a rough surface. Where as if accessible a mechanical inspect device is more accurate . To my opinion from observation. however can not be always accessible.
Tap End Studs (For Studded Flanges) -
Studs threaded on each end with an unthreaded portion on the body diameter. The thread length dimension on one end controls the depth that end will engage into a tapped hole, and also controls the extension length of the stud beyond a studded flange
See https://www.fluidsealingproducts.com/pdf/awhem.pdf
