Newport2
Chemical
- Jan 25, 2021
- 4
Dear all,
for a research project I am designing a Pressure vessel for 8 bar and a small volume. It should be closed by a Bolted Flat End, containing 3 openings. Before taking the reinforcement in consideration (UG-39) the unweakened thickness of the flat head has to be calculated via UG-34. For this the Design Bolt Load W has to be calculated via chapter 2-5 Bolt Loads. For this the Gasket Factors m for Operating Conditions and Minimum Design Seating Stress y from table 2-5.1 have to be used. However I am using a PTFE gasket, and in table 2-5.1 I didn't find any values for m any y of a PTFE gasket. Is it now legitimate to use the manufacturer's values for the factors m and y?
Furthermore, I wonder if one can deduce from chapter 2-5 the bolt loads with which these should actually be tightened. Or should other points be taken into account here? Because that seems inaccurate to me when normally only the standardised values from table 2.5-1 are used to determine the bolt loads.
Sorry for the simple questions, but the field is relatively new to me.
Best regards
Newport2
Best regards
Newport2
