GD_P
- Apr 6, 2018
- 128
1) As per ASME B16.5, class 150 arting flanges are not recommended to be used with metallic gaskets, except weld neck & lapped flange.
So for class 150 weld neck flange, considering medium strength bolting (SA 193 B8 cl.2) with metallic gasket (spiral wound), as per ASME B16.5 "user must verify their ability to seat the selected gasket".
Which I have checked using the Sec VIII, man. apdx. 2 gasket seating condition, it is found that bolting area is not adequate.
(FYI: gasket m & Y factor from ASME mand apdx 2).
One more point for high strength bolting (SA 193 B7) it is not necessary to evaluate the seating, but as allow stresses for B7 & B8 cl.2 are same at RT, even high strength boltng is not adequate in this case.
So a) If B7 is adequate as per code, why not B8 cl.2?
b) Contradictory if B8 cl.2 is not adequate as per calculations (for gasket seating conditions), then how B7 can be?
2) As per ASME B16.5 clause 5.3, SA193 B8 cl. 2 is medium strength where as B7 is high strength bolting.
But as per ASME sec II, part D, allow stresses for both are same till 800F, which decreases rapidly for B7 till 1000 & allow stresses for B8 cl.2 decreases by small amount from 900F till 1000F.
Just for sake of information, what could be the intention of the code behind this?
GD_P
GD_P
