Bolts vs Screws 6
ringman
385
ASME Y14.5 'tends' to differentiate between bolts and nuts in the Fixed and Floating fastener formula section.
Is there a consensus amongst engineers/designers/cad operators as to the technical correctness of the definition of bolts verses screws?
Yes, terminology is screwed up. With the mix of different languages these days, who knows what's correct anymore?
I agree there are 'lag screws' and 'lag bolts', but if you order a 'lag bolt', most likely you will get a piece of hardware in a bag or box labeled 'lag screw'.
Yes, there are 'socket head cap screws', but not 'socket head cap bolts'. [thumbsup2]
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
ctopher's blog
I can share the swedish definition if someone is interested. We define a bolt as a screw without any threads. A screw is everything else. Still many people name screws as bolts, mostly when the screw is of a large dimension.
Okay, how about this?
A bolt is 25 to 50 yards of fabric, as supplied to a wholesaler.
I challenge you all to solve a GD&T problem with this information. :)
JHG
I would checked Machinery's Handbook and my Engineering Drawing and Design... Both had the same defination, which has already been discussed and is mentioned in CBL's first link.
I agree that having screws/bolts be able to "morph" depending on useage is unacceptable. I hate to disagree with what I have considered an infalliable resource (Mach. Handbook), but this is where I'm making my stand!
My definition is going to be: If it will not accept a nut or is installed with a screwdriver, it is a screw. Otherwise, it's a bolt. And before we get into another debate, screwdrivers are flathead or phillips. I don't want to hear about "screwdrivers" with sockets for hex heads. Those aren't screwdrivers in my book. I don't know what they are. I guess boltdrivers.
I'm also not sure where other configurations of internal driving mechanisms fall (i.e. square, star, etc). I suppose since I definately would say that socket heads are bolts, then those would be bolts (unless they will not accept a nut of course!).
-- MechEng2005
A "screwdriver" is not called that because it only installs 'screws', it is because of its 'twisting' motion.
Therefore, no matter what type of head it has on it, it's a screwdriver. There are also 'nut drivers', same family as the screwdriver, but with a permanent socket end.
Chris
AutoCAD 06/08
ctopher's blog
ctopher,
A screwdriver is also a mixture of vodka and orange juice, ideal for removing the bolt of cloth your female companion has wrapp... oops!
The original post asked about how ASME Y14.5M-1994 differentiates between bolts and screws. The final question was "Is there consensus...". Evidently, the answer to that is "No!"
JHG
Those are my favorite screwdriver! [lol]
I agree...no consensus. Which is OK, as long as we know how to pick the correct screw or bolt for our designs.
Chris
AutoCAD 06/08
ctopher's blog
I go with my gut but to be technical I would look at ASME B18.12-2001, "Glossary of Terms for Mechanical Fasteners".
Marcelino Vigil
GDTP T-0377
CSWP
Well, I think historically, a screw is a threaded rod-like object that uses mechanical advantage to displace or move something else as a function of its being turned, such as Lead screws, Archimedes’ screw, threadforming screws of various types, ballscrew, thumb screws, and screw propeller.
A bolt is simply a rod whose function involves being placed into something else that is meant to receive it, such as the bolt of a lock, a door hinge bolt and the traditional definition for a bolt.
The confusion might come from the fact that screw drivers are called screw drivers, even they are also used for bolts, which would explain the non-functional distinction I've and others have learned (use a wrench on a bolt, and a driver on a screw)...and the rest is history.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
"A bolt is simply a rod whose function involves being placed into something else that is meant to receive it..."
Yup. Then some nut put a screw thread on one, and things got screwy. Like this thread <bolting for the door>
There is no standard to justify this but I have noticed often that the difference between a bolt and screw depends on it's size, and were you work.
My last employer was a pipe foundry. The smallest fastener we had was a 3/8 SHCS. Everything there was a bolt. If you asked for a screw you would get a wood screw.
Now I work at for a semiconductor company were a 3/8 fastener is considered very large. We go down to a '0' on some applications. Everything here is a screw.
I will add that personally I go with the Machinery Handbook definition based on what the hardware is going into.
There you go JamesBarlow, I too went from pressure vessels, piping and structural, to optics and lasers and experienced the same thing.
In CPI work, all is 3/4" bolts and studs. In optics, it's all small screws, down to #00, or 1 to 1.5 UNM.
So we really go by 1)our industry, and 2) whatever the screw/bolt standard calls the fastener.
ctopher - I said I didn't want to hear about it! ;P
Maybe your screwdrivers can have something besides phillips and flathead, but mine don't! I'm putting my foot down on this. You can't change my tools!
Thanks to virgildesign I looked up and copied these definitions from ASME B18.12-2001:
3.1.1 Bolts
3.1.1.1 bolt: an externally threaded product designed
for insertion through holes in assemblies to mate
with a nut and normally intended to be tightened or
released by turning that nut. The only bolt that has a
washer face is the heavy hex structural bolt.
3.1.2 Screws
3.1.2.1 screw: a headed and externally threaded
mechanical device having capabilities that permit it to
be inserted into holes in assembled parts, of mating
with a preformed internal thread or forming its own
thread and of being tightened or released by wrenching
its head. Refer to Table 2 for a listing of type designations
for tapping screws and metallic drive screws.
