Bolts vs Screws 6
ringman
385
ASME Y14.5 'tends' to differentiate between bolts and nuts in the Fixed and Floating fastener formula section.
Is there a consensus amongst engineers/designers/cad operators as to the technical correctness of the definition of bolts verses screws?
MechEng, you don't have hex drive or torx/star drive screw drivers? Not even exchangeable bits for a ratchet or electric driver?
What kind of an engineer are you?;-)
KENAT, probably the least qualified checker you'll ever meet...
Well CheckerRon you were typing as I was.
I think that's probably the answer the OP wanted, is ASME B18.12 referenced (directly or indirectly) by 14.5?
Thanks, CheckerRon, that pretty much jives with the rule of thumb I posted, so think I'll stick with it.
When the people fear their government, there is tyranny; when the government fears the people, there is liberty. - [small]Thomas Jefferson [/small]
Time was when I asked for a box of 1/4-20 screws I got a box of devices that may have hex heads or some variety of screwdriver heads. If I asked for a box of 1/4-20 stove bolts I got a box of devices that were designed to be turned or held by a flat blade screwdriver and an equal number of square nuts. Usually unplated.
When installing the heads on my old flathead Ford V8, I never screwed "head screws" into the block. In fact I have never heard of "head screws" I have heard bikers threaten to do something similar to their enemies.
Bill
"Why not the best?"
Jimmy Carter
"Why not the best?"
Jimmy Carter.
Then why have we gotten the worst from Jimmy Carter?
Kenat - I have the tools that perform the same function as you mentioned, but the ones I have are hex/torx/star BOLT drivers. Certainly not screwdrivers... I don't know where you shop that you get "screwdrivers" that are used on bolts. Maybe if it's manufactured in a foreign country it is a translation mistake.
-- MechEng2005
MechEng,
Screwdrivers is the common term. I've never even seen bolt drivers as a term before. I hope you are being sarcastic. If so, sorry for not catching on. If not, do a search on McMaster-Carr for screwdriver to see. The do one for bolt driver.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
fcsuper,
Yes, I was being sarcastic. Just trying to have a little fun with the topic. The fact is that if you ask me for a screwdriver to put in a socket head, I'll hand you the right tool. If I asked you for a bolt driver for a socket head, I suspect I would get the proper tool. =)
It's just sometimes fun to "play" with a topic. Engineer's don't get enough "play" time (at least where I work). It's either right or wrong. Sometimes I think things should be "technically wrong, but fun/amusing."
-- MechEng2005
No, it's an Allen Key
I'd call it a socket head cap screw driver. :)
Joe
SW Office 2006 SP5.1
P4 3.0Ghz 1GB
ATI FireGL X1
An allen wrench could be termed as an allen wrench. It would be USED to torque a socket head BOLT though, not a socket head screw.
In my opinion anyways
-- MechEng2005
ctopher
It's the verb, not the direct object.
How do you torque a socket set screw?
(which our friend MechEng2005 might call a socket set bolt)
To my Good Buddy KENAT:
As I recall "allen key" tried unsuccessfully to run for president, and to beat Barack out of the Illinois senate seat---or was that keyes?
btrueblood had the right idea back on 25 August ... the standard talks about fixed vs floating fasteners, not screw vs bolt. Beyond that, the mental extension to screws & bolts is natural because a nut & bolt work together as a pair to secure mating components between them, whereas a screw is threaded directly into the workpiece ... which is how fixed & floating fasteners work respectively.
Jim Sykes, P.Eng, GDTP-S
Profile Services TecEase, Inc.
