assafwei
Materials
- Jul 20, 2008
- 89
I am trying to simulate the following (see image attached): A "box" made of a polymer, the box walls are around 2mm thick and the general dimensions of the box is around 200x200x50mm. The box has 2 nipples one on each side. I am trying to simulate a "burst pressure" test, in reality one of the nipples is capped and the other one is connected via a flexible hose to a pressure source. Since this box is made of a polymer and the walls are not very thick the deformations are substantial (a few millimeters of translation on top and bottom walls), in real life the box might move freely to accommodate for this deformation and I am having a hard time to create boundary conditions that will prevent rigid body motion
