Bowling Alley Pinsetter Demand Factor
tsears
1
Anyone have a good data set on bowling alley pinsetter electrical load. I am trying to determine an appropriate non-coincident usage demand factor. Word of mouth is that it is a considerably low DF. But the only reliable data I have found was a military guide recommending 70-75 for the entire bowling alley. There will be some constant demand on the pinsetter, but I am not convinced that the motor drawdown is such that I can use any demand factor for this piece of equipment.
Ask the manufacturer what demand factor he recommends. You could also use a strip chart recorder on an actual bowling alley machine to measure the operating time of the pinsetting motor. Then, allow a bit of safety factor in case you get some no nonsense bowlers that push the machine as fast as it can go.
Well, it's been my experience that it typically takes 8 league bowlers about 2.5 hrs to bowl 80 frames on two lanes. That works out to a maximum of about normal pin sets.
Most places I've been to, there's usually a few glitched pin sets per game.
TTFN
