mscatoloni
Aerospace
- Jan 14, 2003
- 4
- 0
- 0
We have machined a hydraulic 90 deg elbow pipe fitting from 360 Brass Alloy (Size -16, 1" OD line) (aprox 600 elbows made). A sample of 13 was subjected to the Mercurous Nitrate Test (ASTM-B154) and 3 of 13 parts were observed to have cracks on the OD radius and wrench pad area. Can anything be done to the "finished part", (which has taper pipe threads), to stress relieve bake the apparent residual stress and cracking that was observed ? ....without compromising the thread geometry from heating ?
A sample of the 360 Alloy Brass forging was Merc Nitrate Tested (successfully)prior to machining it. The elbow was machined on a CNC lathe using standard insert cutting tools (Kenemetal) and water-based coolant was used.
Any idea's to the root cause and possible avoidance of this problem, would be appreciated ???
- Mark S.
- Mark S.
