Bridge pier footing with sheet piling 8
Panars
Geotechnical
Apr 18, 2005
298
For the second time in my career, I have run across an existing bridge pier foundation that consists of a concrete footing with sheet piling around the perimeter. It looks like a normal pile supported pier footing, except there are no piles (like H-piles or pipe piles) under the footing, just the sheet piles around the perimeter. The sheet piles are driven in a rectangle and then the concrete footing is poured inside the sheet piles. The footing is a normal thickness (like 3 to 5 ft, 1 to 1.5 m) and is at the top of the sheet pile.
Does anyone have an idea how they designed these foundations? Are they designed as spread footings with an effective depth 2/3 the depth of the sheet piling (similar to a pile group)?
I don't think the sheet piling could be taking any significant load because the connection between the sheet piling and the concrete footing is relatively small. The connection is probably enough to provide lateral restraint to the top of the sheet piling, but that is it.
Bobby46, this bridge does not have integral abutments. As you noted, it was in the book as having bolted field splices.
You can see the expansion joints on Google Streetview.
The author of this book, Marty Burke, worked at ODOT and was the big proponent of the integral and semi-integral abutments. He is a big reason why Ohio was in the forefront of adopting this technology. Two of my coworkers worked with Mary when he was at ODOT.
You're definitely right. I just assumed it was an integral abutment bridge based on the title of the book. Back to the drawing board...
Edit: Picture was from the next bridge downstream
