Bug with offset and corners NX 6
ChevyM
Automotive
Feb 9, 2012
90
i wanted to share this with you guys.
plz look at the attachment:
its a square with round corners and an offset on the inside.
as you can see i used some expressions. if u change the thickness to 3, a bug appears. but if u change it to 2, and then to 3. its the way its supposed to be.
i dont know if this is a known bug, and i had no idea how to search for this if it was already posted, sorry if it was, but test it yourself. and does anyone know how this is possible?
so.
open the part.
change the thickness to 3 and see it yourself
but when u make it 2 and then 3, its good.
awkward don't you guys think?
when i dont use the offset but make a square with constrains and midpoints etc,(so you have the same idea as an offset) you can change it from 1 to 3 without problems.
Best regards,
Chevy
NX6
Win7, 64 Bit
ah oke, but it isnt a solution, but its known. that's okay then;)
thnx=]
Best regards,
Chevy
NX6
Win7, 64 Bit
