Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The article can be found here:Could you point me/us to that MSC article?
Thanks for the checklist I will look into the shear flow examples. Do you know of a reference I can consult?its just a beam, no?
calculate section properties
apply loads
calc local bending moments; determine stresses at extreme fibers and stresses in flange sections
calc local shear loads; determine shear flows in each part of cross-section; this can be hard with a complicated cross-section as shown above; see aircraft multibox shear flow examples; determine shear stresses in each part of section
check beam deflections
check local buckling in flange and web sections
check beam lateral/torsional buckling
check connections at ends
or shear flow due to torsion loading Google "multicell wing box shear flow" --> lots of links, for instance
well, it depends on the loading and how the beam is attached.
Also, thanks SWComposites, I’ll take a look at shear flow as it might be useful later
