imren
- May 13, 2014
- 18
I have a problem with a Bystronic Bystar 4020 3kw laser.
In the resonator cabinet where the laser beam is formed i the glass tube water splashed everywhere.
Every connection on the water tubes was wet. I can't see that any of a tube broke or fell out.
The laser was running when that happened I shut it down and everything was fine luckily.
After the water dried I turned on the main switch started the water pump but I can't see where the water leaks.
I suppose that the water in resonator is flowing after the laser cabinet is turned on?
How to turn on the laser cabinet to see where the water is leaking but without turning on the high voltage?
I tried to do this with MSC with local and step turned on. I tuned on the vacuum pump but I still don't see any water leak in resonator cabinet. Does anybody know when the water starts to flow in resonator?
