For a glass facade, on the range of L/50 under 50 yr winds to prevent damage to the glass and sealants. For seciceability wind loads, it's more about not frightening the villagers.
The trick is to realize that your facade will be likely be assembled from multiple lites connected to the cables near the edges of those lites. As such, cable deflection results in essentially no glass deflection but a whole lot of rotation in the sealant joints between lites.
Exactly. Of course, I'm just guessing at what I think OP might be up to.
Glass itself can tolerate a surprising amount of out of plane deflection too. L/50 would be a bit much though.
I know of no code specifying applicable deflection limits pratamahrs. If you find one, I'd love to hear about it.
The amount of pre-tensioning load to the single cable will depend on the permissible deflection of the cable. While there are no standards mentioning this allowable deflection, it is worthwhile to know if it is better to prove by testing or by theory. L/50 would be ideal but up to what span?
