Ralph2
Industrial
- May 3, 2002
- 345
Hello / help![[bigsmile] [bigsmile] [bigsmile]](/data/assets/smilies/bigsmile.gif)
I have a large cast steel disk, ~44" diameter flat on one side, ~1.375" wide at rim and tapered to ~5" wide on the other side. I need to balance this, and do so by machining a segment off the periphery. Calculating the depth and / or length of chord to match the weight required is a bit tricky.
So, I have modeled a segment in SW 2014, and by varying the depth I can use the mass properties to determine how heavy that segment would be (and obtain the length and thickness of the piece). However this is a bit of trial and error to get it exact.
Is there some clever way to make the weight the driving control of my depth measurement.![[ponder] [ponder] [ponder]](/data/assets/smilies/ponder.gif)
I have attached (I hope) my *.SLDPRT to assist if possible a solution to this.
Thank you for your time
Ralph
Ralph
