Calculating minimum air gap, part II
zappedagain
1,074
Sorry for the dual post - this wasn't getting any responses in the other group so I'm reposting here...
I'm designing a circuit to meet the CE mark test of 8KV discharge. I read through thread797-134233: calculating minimum air gap and saw a discrepancy that I'm looking to answer.
The dielectric breakdown of air is 3KV/mm, or about 76KV/inch.
I believe I have a copy of the 'Sparkgap breakdown voltages for needle gap' referenced in that thread (I'm not sure because I received it from a colleague in the mid-90s). This table shows a breakdown voltage of about 26KV/in at 25C, 29.9 In Hg baromteric pressure.
That's almost a 3:1 discrepancy between the two techniques. While the chart is more real-world, that seems a rather large safety factor. Are there some other facts that explain the difference between the two techniques? For example, the chart shows that at -40C and 60 In Hg you need to apply a correction factor of 2.30 so that almost accounts for it; those aren't typical operating conditions though.
What I really want to know is: How far do I need to keep my traces from the aluminum enclosure (that is perpendicular to the PCB) to not have the an ESD event jump onto my PCB traces?
Two things. Needle points arc at lower voltages than blunt things.
Is the CE arc discharge at the AC power cord or a spark to the operator panel?
Paschen's law has a lot to say about this. You cannot use a single number to get the breakdown voltage for a certain distance. See
Gunnar Englund
100 % recycled posting: Electrons, ideas, finger-tips have been used over and over again...
Thanks all! That helps. I have planes, not points.
sreid -
CE mark requires ESD testing per EN 61000-4-2:1995. The following tests are required:
Surface Test voltage Contact method
Conductive surfaces +/-4 KV Direct
Non-conductive surfaces +/-8 KV Air discharge
Reference ground planes +/-4 KV indirect discharge
Z
Was cleaning house and ran across a NASA Tech Brief titled, "Approximations for Predicting Electrostatic Discharges," dated April, 1988, from vol. 12, no. 4, Item #122 or JPL Invention Report NPO-17065/6582. A veritable truckload of equations. Haven't read it through, but it looks interesting.
TTFN
FAQ731-376
