sloth4z
- Aug 12, 2003
- 132
I am trying to find the density of air going into a fan system based on Dry and Wet Bulb Temperatures and Pressure. AMCA Publication 203 says to use the spychometric chart. Is a chart really the best way to go? All of the lines in the chart are straight which leads me to believe that there should be a simple formula to calculate it. Can someone enlighten me as to why a chart is used to calculate moist air density?
I've seen a calculator on the internet that calculates it for you. Do calculators like this contain tabulated data that is interpolated, or do they use the formula I am looking for?
