I have a 10" wall with vertical steel located in the middle. I am checking to see if it matters what side the contractor ties the horizontal steel. when calculating "d" for both locations, if the steel is located on the tension side, do I need to substract db for the vertical steel along with 1/2db of the horizontal steel or just ignore the vertical steel all together? thanks.
