KAMAL HOSEN
- Sep 8, 2023
- 14
I’m assessing the performance evaluation of a 10-year-old steel structure in a substation. The design strength for steel was 36000 psi. It has naturally corroded (slightly, seems rust and pitting corrosion, not too much just slightly corrosion). Is there any equation to calculate the current strength of the steel? I don’t want to use 36000 psi, and a steel plate test is not possible at this time.
Thanks in advance.
Thanks in advance.
